1.Click Site on the taskbar to open the Site pane.
2.Right-click the root node My Network and then select Open Overview Map from the drop-down menu. The overview map opens, and sites are organized in the hierarchy view by default.
Tip: To send the overview map shortcut to the system desktop for quick access, select Send Overview Map to Desktop.
3.To change to the topology view, click Hierarchy View at the upper-left corner and select Topology View from the drop-down list.
4.To view the site properties in detail, point to the site icon and the site properties are displayed in a tip box.
Tip: The overview map can be automatically updated when sites are rebuilt in the Site Manager or recalculated in a Scheduled Benchmark Task.
Note: The overview map itself cannot be changed. You can click the
icon to save it as another map file.
