Browsing Domains under a Tenant
1.Log into Tenant Management page.
2.In the Tenant Management page, select the Domain List tab. All domains inside the tenant are displayed. You can view the overall information of each domain, such as the available node size, and accessible users.
Tip: The Maximum Nodes column displays both the maximum node count that the domain can host and the used nodes. To modify the maximum node size, see Configuring Domain Properties for more details.
Tip: To delete a domain, right-click it to select Delete.
Creating a Domain
