To reuse configurations for network change tasks in the future, you can pre-define it as a config template. When Defining the Change Node, you can directly load a config template instead of writing commands manually.
Proceed with the following steps to create a configuration template:
1.Click Network Change on the taskbar.
2.In the Network Change pane, click Configuration Templates.
3.In the Manage Configuration Templates pane, point to a folder and click the drop-down menu to select New Template.
4.In the Configuration Template Properties dialog, enter the template name and commands.
5.Click Save to complete the configuration template.
