1.Prepare a CSV file in your local folder. The table headers must be consistent with the following sample.
Note: Make sure that all devices on the path are existing in the domain. Otherwise, the path cannot be imported.
Tip: You can use exported files as templates.
2.Click Path Browser on the taskbar.
3.Click Import > Browse to select the file, and then click Browse.
Note: If a path with the same name already exists in the Path Browser, the existing one will be replaced by the new one.
