1.Click Path Browser on the taskbar.
2.To select a data source for recalculation, right-click the target path entry and select the corresponding menu from the drop-down menu.
Tip: To recalculate multiple paths at one time, select the paths by pressing the Ctrl or Shift key. To recalculate the path instantly with other path settings, right-click the target entry and then select Add to Path Calculation Bar.
Calculate Live Network — calculate the path with live data
Calculate Historical Data — calculate the path with historical data. See Data Source in Path Settings for more details.
3.Click Calculate to start the recalculating process.
Path Settings
