Use this API to get the user information of a user.
Method |
URL |
Required authentication |
Get |
/V1/CMDB/Users |
Yes |
Name |
Token*required |
username |
The name of the user that you get the information. If not specified, the API returns the information of all users. |
Parameter |
Type |
Example |
userData |
List |
The returned user information. It contains the following parameters: ▪username: the user name. ▪email: the email address of the user. ▪firstName: the first name of the user. ▪lastName: the last name of the user. ▪password: the login password. ▪authenticationType: the authentication type of the user account. o1: Local o2: External ▪phoneNumber: the phone number of the user. ▪department: the department that the user belongs to. ▪description: the description of the user account. ▪allowChangePassword: whether the user can change the password. ▪deactivatedTime: the time when the account is expired. ▪isSystemAdmin: whether the user is an administrator. ▪tenantsAndRoles: tenants that the user can access and the user roles. otenantId: the tenant that the user can access. oisAdmin: decide whether to allocate the tenant administrator role to the user. ocanAddDomain: decide whether to allow the user to create domains. |
statusCode |
integer |
statusDescription |
string |
