Use this API to get the value of a specific attribute of a module.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Modules/Attributes |
Yes |
Name |
Token*required |
moduleName*required |
The module name of a device. |
hostname*required |
The hostname of a device. |
attributeName |
The name of the attribute that you want to get it value. If not specified, return all attributes and their values. |
Parameter |
Type |
Example |
hostname |
string |
The hostname of the returned device. |
attributeName |
string |
The name of the attribute. |
moduleAttributeValue |
integer |
The value of the attribute. |
statusCode |
integer |
statusDescription |
string |
