Use this API to get the value of a specific attribute of a device.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Devices/Attributes |
Yes |
Name |
Token*required |
attributeName |
The name of the attribute that you want to get value. If not specified, return all attributes and their values. |
hostname*required |
The hostname of a device. |
Parameter |
Type |
Example |
Attributes |
Object |
An attribute set. |
attributeName |
string |
The name of the attribute with its value returned. |
hostname |
string |
The hostname of the returned device. |
statusCode |
integer |
statusDescription |
string |
