This function returns the path status.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Path//Calculation/{taskID}/Status |
Yes |
Name |
Token*required |
The token can be obtained by sending a POST request to the log in session endpoint and provide valid credentials. |
taskId*required |
The task ID retrieved from Calculate a Path. |
Parameter |
Type |
Example |
statusCode |
integer |
Code issued by NetBrain server indicating the execution result. |
statusDescription |
string |
resultCode |
integer |
The status code of a path. ▪0: Initialized ▪1: Running ▪2: Succeeded ▪3: Failed ▪4: Canceled |
resultDescription |
string |
The explanation of the result code. |
