This function is used to calculate a path between two endpoints. The result will be returned in the form of a path ID, and you can use the path ID in the Get Path Calculation Result as the request parameter to get each hop information of the path.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Path/Calculation |
Yes |
Name |
Token*required |
The token can be obtained by sending a POST request to the log in session endpoint and provide valid credentials. |
body*required |
The request body contains the following parameters: ▪sourceIP*(string): IP address of the source device. ▪sourcePort (integer): Source protocol port, for example, 23 for telnet. This parameter can be null. ▪sourceGwIP* (string): Gateway for path calculation. osourceGwDevice*: Hostname of the gateway device. osourceGwIntf*: Name of the gateway interface. ▪destIP*(string): IP address of the destination device. ▪destPort (integer): Destination protocol port, for example, 23 for telnet. This parameter can be null. ▪pathAnalysisSet* (integer): Path type used to calculate. o1: L3 Path o2: L2 Path o3: L3 Active Path ▪protocol* (integer): Application protocol, for example, 4 for IPv4, and 6 for TCP. ▪isLive (integer): Data source used to calculate the path. o0: use data from the current baseline. o1: use data via live access. Example: { |
Parameter |
Type |
Example |
taskId |
string |
The ID of the task. |
statusCode |
integer |
Code issued by NetBrain server indicating the execution result. |
statusDescription |
string |
