This function returns the hop information of a path calculated through the Calculate a Path API.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Path/Calculation/{taskID}/Result |
Yes |
Name |
Token*required |
The token can be obtained by sending a POST request to the log in session endpoint and provide valid credentials. |
taskID*required |
The task ID returned in the Calculate a Path API. |
Parameter |
Type |
Example |
statusCode |
integer |
Code issued by NetBrain server indicating the execution result. |
statusDescription |
string |
hopList |
list |
A list of hops along a path. |
hopId |
string |
The ID of a hop. |
srcDeviceName |
string |
The hostname of the source device. |
inboundInterface |
string |
The name of the inbound interface. |
mediaName |
string |
The media name. |
dstDeviceName |
string |
The hostname of the destination device. |
outboundInterface |
string |
The name of the outbound interface. |
nextHopIdList |
list |
A list of the IDs of next hops. |
