Get the status of a benchmark task
Use this API to get the status of a benchmark task.
Resource Information
Method
URL
Authentication
GET
/V1/CMDB/Benchmark/Tasks/{task}/Status
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
task*required
(path)
The ID or name of the benchmark task.
Response
Parameter
Type
Description
Example
taskStatus
integer
The status of the scheduled task. Possible values:
1: Unknown
0: Never run
2: Running
10: Succeeded
11: Succeeded with warnings
20: Failed
30: Manually stopped
31: Automatically stopped due to timeout set by users or another system setting.
  "taskStatus"0,
  "statusCode"790200,
  "statusDescription""success"
statusCode
integer
The returned status code of executing the API.
statusDescription
string
The explanation of the status code.
