Use this API to get the status of an L2/L3 topology building task.
Method |
URL |
Required authentication |
Get |
/V1/CMDB/Topology/Tasks/{task}/Status |
Yes |
Name |
Token*required |
taskId*required |
The ID of a topology building task. |
Response
Parameter |
Type |
Example |
status |
string |
The status of the topology building task. |
statusCode |
integer |
statusDescription |
string |
