Use this API to get the results of tuning devices.
Method |
URL |
Required authentication |
Get |
/V1/CMDB/TuneDevices |
Yes |
Name |
Token*required |
taskId (string) |
The task ID of tuning devices. |
begin (int) |
Specify from which row to begin indexing data. For example, the begin is 0, and the API will return tuning result starting from the first row. This parameter is required when the hostnames parameter is not specified. |
count (int) |
Specify the maximum number of returned data. This parameter is required when the hostnames parameter is not specified. |
hostnames (list) |
List all devices that need to return tuning result. ▪if this parameter is specified, the begin and count parameters are useless. ▪If not specified, use the begin and count to return tune results. |
Parameter |
Type |
Example |
devices |
list |
A list of devices that return tuning result. |
deviceName |
string |
The name of a tuned device. |
log |
string |
The log of device tuning. |
tuneState |
object |
The tune state. |
enable |
string |
The result of logging into Enable mode. |
hostname |
string |
The hostname of a tuned device. |
liveHostname |
string |
The live hostname of a device. |
login |
string |
The login result of a device. |
mgrIntf |
string |
The management interface of a device. |
mgrIp |
string |
The management IP of a device. |
model |
string |
The model name of a device. |
networkServer |
string |
The front sever name of a device. |
ping |
string |
The ping result. |
snmpRo |
string |
The SNMPRO information of a device |
telnetSSH |
string |
The Telnet and SSH result of a device. |
vendor |
string |
The vendor name of a device. |
deviceName |
string |
The device name. |
log |
string |
The log of tuning a device. |
statusCode |
integer |
statusDescription |
string |
