Use this API to get the front server associated with a device.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Devices/{hostname}/FrontServer |
Yes |
Name |
Token*required |
hostname*required |
The hostname of a device. |
Parameter |
Type |
Example |
alias |
string |
The alias of the Front Server. |
ipOrHostname |
string |
The IP address or name of the Front Server. |
statusCode |
string |
statusDescription |
string |
