Use this API to get the connected layer 2 switch ports of an end system.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Topology/Devices/{ip}/ConnectedSwitchPort |
Yes |
Name |
Token*required |
ip*required |
The IP address of a device interface. |
Parameter |
Type |
Example |
hostname |
list |
The hostname of the device that the end system connects to. |
interface |
string |
The interface that the end system connects to. |
statusCode |
integer |
statusDescription |
string |
