Use this API to get the configuration of a device.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/DataEngine/DeviceData/Configuration |
Yes |
Name |
Token*required |
hostname*required |
The hostname of the device that you want to get the configuration. |
Parameter |
Type |
Example |
configuration |
string |
The full context of the configuration of the device. |
{'configuration': '!\r\n! This config file is generated via SNMP\r\n!\r\n! |
time |
string |
The last update time of the device configuration. |
statusCode |
integer |
statusDescription |
string |
