Get all modules of a device
Use this API to get all modules of device specified by hostname.
Resource Information
Method
URL
Required authentication
GET
/V1/CMDB/Modules
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
hostname*required
(query)
The hostname of a device.
Response
Parameter
Type
Description
Example
Modules
list
A list of all modules.
  "statusCode"790200,
  "statusDescription""success",
  "modules": [
    "module1","module2""module3"
statusCode
integer
The returned status code of executing the API.
statusDescription
string
The explanation of the status code.
