Get all devices in a domain
Use this API to get the corresponding device by an IP address or device name. If neither hostname nor IP address is set, return all devices in the current domain.
Resource Information
Method
URL
Required authentication
GET
/V1/CMDB/Devices
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
hostname
(query)
Enter hostname to find the corresponding device’s details.
If neither hostname or IP address is set, all devices of the current domain will be returned.
If both hostname and IP address are set, the hostname will take precedence.
ip
(query)
Enter an IP address to find the corresponding device’s details.
Response
Parameter
Type
Description
Example
devices
list
A list with of devices in a domain.
  "statusCode"790200,
  "statusDescription""success",
  "devices": [
      "id""7d47c791-84cb-4bdb-9d2c-abbfafe71b2e",
      "mgmtIP""10.10.7.253",
      "hostname""Bos-Core",
      "deviceTypeName""Cisco Router"
id
string
The ID of a device.
mgmtIP
string
The management IP of a device.
hostname
string
The hostname of a device.
deviceTypename
string
The device type of a device.
statusCode
integer
The returned status code of executing the API.
statusDescription
string
The explanation of the status code.
