It is essential to have a successfully executed system benchmark to keep domain data up-to-date, as it does not only benchmark your network but also update network topologies, re-calculate sites, rebuild visual space, and update map.
The system provides the following two types of logs:
▪Execution log — records the overall status of all subtasks, such as building topology, recalculating sites.
▪Device Log — records the live access process for each device, including data retrieval process.
Example: Verify benchmark result by browsing logs.
2.In the Domain Management page, select Operations > Discovery/Benchmark Task from the quick access toolbar.
Tip: You can view the latest execution result of all benchmark tasks from the Last Result column. To view the detailed latest execution log of a benchmark task, click the hyperlink (such as Succeeded) in its Last Result column.
3.Right-click the target task entry and then select View Log from the drop-down menu.
4.In the following dialog, select the log type to view in the Log column.
Tip: To export the log, point to the target task entry and click the
icon to select Export Execution Log or Export Device Log. The default location of the exported file is C:\Users\<your username>\Downloads.
Click the |
