Use this API to edit a network credential.
Method |
URL |
Required authentication |
PUT |
/V1/CMDB/NetworkSettings |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪privateKey (object): used to add a private key. It contains the following subparameters: oalias* (string): the alias of the private key. okeyName (string): the name of the private key. omd5KeyContent (string): the MD5 content of the key. okeyContent (string): the content of the key. opasswordPhrase (string): the passphrase of the key. ▪jumpBox (object): used to add a jump box setting. It contains the following subparameters: oalias* (string): the alias of the jump box. oipAddr (string): the IP address of the jump box. omode (int, mandatory): the access mode from the Front Server to the Jump box. ➢0: Telnet ➢1: SSH ➢2: SSH Public Key oport (integer): the port of the access port such as 23 for telnet. ousername (string): the username to access the jumpbox. This parameter is mandatory only if the mode is 1 or 2. opassword (string): the password to access the jumpbox. This parameter is mandatory only if the mode is 1. okeyName (string): the name of the SSH public key. This parameter is mandatory only if the mode is 2. ologinPrompt (string): the login prompt to connect the jumpbox. opasswordPrompt (string): the login password to connect the jumpbox. ocommandPrompt (string): the prompt to enter CLI command, such as >. oyesNoPrompt (string): the prompt to save the SSH key. otelnetCommand (string): configure a special command to access via Telnet when necessary. For example, telnet $(IP) $(PORT). oSSHCommand(string): configure a special command to access via SSH when necessary. For example, ssh -l $(USERNAME) -p $(PORT) $(IP). ocmd2 (string): the login command for the special command. ocmd2PasswordPrompt (string): the login prompt to connect the jumpbox for the special command. ocmd2Password (string): the login password to connect the jumpbox for the special command. ocmd2ModePrompt (string): the mode prompt for the special command. oquitCmd (string): the quit command. ▪telnetInfo (object): used to add telnet/SSH login credentials. It contains the following subparameters: oalias* (string): the alias of telnet/SSH login credentials. ousername (string): the username of the non-privileged login. opassword (string): the password of the non-privileged login. ocliMode (integer): the authentication method. ➢0: Telnet/SSH Password ➢2: SSH public key. okeyName (string): the name of the SSH public key. This parameter is mandatory only if the cliMode parameter is 2. ▪privilegeInfo (object): used to add privileged credentials. oalias* (string): the alias of the privileged credentials. ousername (string): the username of the privileged login. opassword (string): the password of the privileged login. ▪snmpInfo (object): used to add SNMP credentials. oalias* (string): the alias of the SNMP credentials. osnmpVersion (integer): the version of the SNMP string. ➢1: SNMP v1 and v2c ➢3: SNMP v3. ➢The other parameters are different based on SNMP versions. •SNMP v1 and v2c: oroString (string) and SNMP read-only community string. •SNMP v3: v3 information will be effective. oroString (string): SNMP read-only community string. ov3 (object): Settings if SNMP v3 is applied in snmpInfo.snmpVersion. ➢authMode (integer): the authentication mode of SNMP V3. •1: no authen no priv •2: auth no priv •3: auth priv ➢authPro (integer): the authentication method of SNMP V3. Effective when snmpInfo.v3.authMode is 2 or 3. •1: md5 •2: SHA ➢encryptPro (integer): the encryption method. Effective when snmpInfo.v3.authMode is 3. •1: DES •2: AES, •3: AES192, •4: AES256. ➢username (string): the username to access the network devices. ➢contextName (string): the context name of authentication privilege. ➢authPassword (string): the authentication password. This field is effective when the authMode is 2 or 3. ➢encryptPassword (string): the encryption password. This field is required when the authMode is 3. Example: { |
Response
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
