This section introduces the hardware requirements, network connectivity requirements, and more prerequisites for deploying a distributed system.
Reference Specification
Network Connectivity Requirements
Deployment Prerequisites
As the number of network devices and concurrent users increase, the system requires a distributed environment, which requires more machines to provide resiliency and scale out flexibly based on your network scale. Both physical machines and virtual machines are supported.
Select an appropriate deployment way according to your node count:
Distributed deployment for 2001-5000 nodes
Distributed deployment for 5001-10000 nodes
Distributed deployment for 10001-50000 nodes
Distributed deployment for 2001~5000 nodes
Environment
NetBrain Component
Machine Count
CPU
Memory
Hard Disk 1)
Operating System
2001~5000 nodes
≤20 users
Web Server
Web API Server
Cache Server
Message Server
Task Engine
Front Server Controller
1
4 Core/
8 vCPU
32GB
200GB
Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit
Windows Server 2016 (Standard/Datacenter Edition), 64-bit
Worker Server
1
8 Core/
16 vCPU
32GB
200GB
Front Server
1
4 Core/
8 vCPU
8GB
200GB
Windows Server 2008 R2 SP1, 64-bit
Red Hat Enterprise Linux (RHEL) 7.0/7.3/7.5, 64-bit
CentOS 7.0/7.2, 64-bit
MongoDB Server
License Agent Server
Index Server
1
4 Core/
8 vCPU
32GB
500GB
Distributed deployment for 5001~10000 nodes
Environment
NetBrain Component
Machine Count
CPU
Memory
Hard Disk 1)
Operating System
5001~10000 nodes
≤50 users
Web Server
Web API Server
Cache Server
Message Server
Task Engine
1
8 Core/
16 vCPU
32GB
200GB
Worker Server
2
8 Core/
16 vCPU
32GB
200GB
Front Server
2
4 Core/
8 vCPU
8GB
200GB
MongoDB Server
Index Server
1
8 Core/
16 vCPU
64GB
1TB
Distributed deployment for 10001~50000 nodes
Environment
NetBrain Component
Machine Count
CPU
Memory
Hard Disk 1)
Operating System
10001~50000 nodes
≤200 users
Web Server
Web API Server
Cache Server
Message Server
Task Engine
1
8 Core/
16 vCPU
32GB
200GB
Worker Server
3
8 Core/
16 vCPU
32GB
200GB
Front Server
3~10 2)
4 Core/
8 vCPU
8GB
200GB
MongoDB Server
Index Server
1
8 Core/
16 vCPU
128GB
2TB
Notes:
1) The required hard disk space must be exclusively reserved for NetBrain. For better performance, MongoDB Server is recommended to be installed on a machine equipped with Solid State Drive (SSD), or Hard Disk Drive (HDD) RAID-10.
2) Each Front Server is recommended to manage 5,000 network nodes at most.
3) The sentinel node of Cache Server Cluster can be installed on any one of Worker Servers.
Source
Destination
Protocol and Port Number
Thin Client
Web Server
Web API Server
HTTP/HTTPS (80/443)
Web API Server
Worker Server
Task Engine
MongoDB Server
Index Server
TCP 27017
TCP 27654
TCP 9200
Web API Server
Worker Server
Cache Server
TCP 6379/7000
Web API Server
Worker Server
Task Engine
Message Server
TCP 4369/5671/5672/15672
Worker Server
Task Engine
Front Server
TCP 9095
Front Server
Live Network
ICMP/SNMP/Telnet/SSH/REST API
Cache Server
Cache Server
TCP 16379/26379
Message Server
Message Server
TCP 25672
MongoDB Server
MongoDB Server
TCP 27017
Index Server
Index Server
TCP 9300
