You can directly delete data views in the Data View Pane.
1.On a map, click the
icon to open the Data View pane.
2.Point to the global data view (marked with the
icon), and click the
icon to select Delete.
▪Delete for All Devices — delete the global data view completely from the system.
Tip: You can also delete a Global Data View from the Data View Manager.
▪Delete for this Map Only — delete data views for matched devices on this map only, and keep for others. As a result, this global data view still can be browsed in the Data View Manager for the rest of devices.
2.Point to the activity data view (marked with the
Note: If the data view is generated by a Qapp, and the Qapp is running periodically, you need to stop the running task first before deleting the data view.
2.Point to the map data view (marked with the
Tip: You can also delete a Map Data View from the Map Data View Manager.
