Use this API to delete a specific network setting.
Method |
URL |
Required authentication |
DELETE |
/V1/CMDB/NetworkSettings |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪privateKey (object): the private keys. Input the alias of the private key: oalias* (string): the alias of the private key that you want to delete. ▪jumpBox (object): the jump box settings. Input the alias of the jump box: oalias* (string): the alias of the jump box that you want to delete. ▪telnetInfo (object): the telnet/SSH login credentials. Input the alias of the telnet/SSH login credentials: oalias* (string): the alias of telnet/SSH login credentials that you want to delete. ▪privilegeInfo (object): the privilege credentials. Input the alias of the privilege credentials: oalias* (string): the alias of the privilege credentials that you want to delete. ▪snmpInfo (object): the SNMP credentials. Input the alias of the SNMP credentials: oalias* (string): the alias of the SNMP credentials that you want to delete. Example: { |
Response
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
