Use this API to delete a role.
Resource Information
Method
URL
Required authentication
DELETE
/V1/CMDB/Roles/{Rolename}
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
roleName*required
(path)
The name of the role that you want to delete.
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
