Use this API to delete a map from the current domain.
Method |
URL |
Required authentication |
DELETE |
/V1/CMDB/Maps |
Yes |
Name |
Token*required |
url*required |
The URL of the map that you will delete. |
Parameter |
Type |
Example |
statusCode |
string |
statusDescription |
string |
