Use this API to delete a domain.
Method |
URL |
Required authentication |
PUT |
/V1/CMDB/Domains/{domainId} |
Yes |
Name |
Token*required |
domainId*required |
The ID of the domain that you want to delete. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
