To have a quick access to specified dashboard templates when creating a dashboard, you can customize your favorites in the Dashboard menu of the map toolbar.
1.On a map page, click Dashboard > Customize from the map toolbar.
2.Click + Dashboard Template, and select dashboard templates by clicking Apply, then click Close.
The selected dashboard templates will be placed under the Dashboard Template menu.
2.Point to the Dashboard Template Menu node and click the icon to select New Folder from the drop-down menu.
For how to add templates to the folder, see Adding Templates to Favorites for more details.
