Use this API to create multiple sites. A site will be created as a parent if the site does not have a parent site in the current system.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Sites |
Yes |
Name |
Token*required |
Request*required |
The body contains two parameters: ▪sitePath* (string): the full path of a site, such as My Network/Site1/Boston. ▪isContainer* (bool): specify whether the site to be added is a container site. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
