Create a transaction to start site modification
Use this API to create a transaction to start the site modification. Every time you want to change sites via APIs, you first need to start a transaction.
Resource Information
Method
URL
Required authentication
POST
/V1/CMDB/Sites/Transactions
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
