Use this API to create a parent site.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Sites/Parent |
Yes |
Name |
Token*required |
Request*required |
The body contains one parameter: ▪sitePath* (string): the full path of a site, such as My Network/Site1/Boston. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
