Use this API to create a leaf site.
Resource Information
Method
URL
Required authentication
POST
/V1/CMDB/Sites/Leaf
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Request*required
(body)
The body contains one parameter:
sitePath* (string): the full path of a site, such as My Network/Site1/Boston.
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
