Use this API to create a customized device attribute for certain device types.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Devices/Attributes |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪attributeName*(string): the name of the attribute to be created. ▪attributeDisplayName (string): the display name of the attribute in Device Details pane of NetBrain system. ▪deviceTypeNames*(string): specify the device types that the created attribute applies to. If set to null, it will apply to all device types. See Device Type Name and ID for the available device types. ▪dataType*(string): the supported data types of the attribute, such as string. ▪subDataType (string): this parameter is only available to the attribute in list or table type. ▪isFullSearch*(boolean): set whether to use the property as an index in full scope search, including extended search and default search. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
