In the Network pane, when you click a node, the context maps of the node will display. This section introduces the context maps of each node as you click it.
Node |
Context Maps |
Cluster |
Five context maps are supported for this node: ▪ESXi Host to Layer 3 Neighbors — displays the Layer 3 topology of each ESXi host of this cluster and its gateway devices. ▪ESXi Host to Layer 2 Neighbors — displays the Layer 2 topology between each ESXi host of this cluster and its connected physical switches. ▪VM to Layer 2 Neighbors — displays the Layer 2 connection between each VM of this cluster and its connected vSwitch as well as the connection between the vSwitch and its up-link physical switches. ▪VM to Layer 3 Neighbors — displays the Layer 3 topology of each VM of this cluster and its gateway devices. ▪ESXi Host to VM — displays each ESXi host of this cluster and VMs under the host. |
ESXi Host |
Four context maps are supported for this node: ▪Host to Layer 3 Neighbors — displays the Layer 3 topology of a host and its gateway devices. ▪Host to Layer 2 Neighbors — displays the Layer 2 topology between a host and its connected physical switches. ▪VM to Layer 2 Neighbors — displays the Layer 2 connection between each VM and its connected vSwitch as well as the connection between vSwitch and physical switches. ▪Virtual to Physical — displays the (parent/child) relationship between a host and vSwitch/VMs under the host. |
Resource Pool |
One context map is supported for this node: ▪VM to vSwitch — displays the connection between each VM of this node and its connected vSwitch as well as the connection between the vSwitch and its up-link physical switch. |
VM |
Three context maps are supported for this node: ▪VM to Layer 3 Neighbors — displays the connection between the VM and its gateway device. ▪VM to Layer 2 Neighbors — displays the connection between the VM and its connected vSwitches and external switches. ▪VM to ESXi Host — displays the dependency relationship between the VM and ESXi host. |
Node |
Context Maps |
Port Group |
One context map is supported for this node: ▪Port Group — displays all VMs under this port group as well as the layer 2 connection between the port group's Virtual Standard Switch and external switches. |
VM |
Same as the context maps of the VM node under the hosts and cluster view. |
VDS |
Two context maps are supported for this node: ▪VDS to Layer 2 Neighbor — displays all connected Layer 2 neighbors of this VDS. ▪VDS and ESXi Host — displays the ESXi hosts that the VDS runs on. |
Uplink Port Group |
One context map is supported for this node: ▪Uplink Port Group — displays the connection the Uplink Port Group and external switch. |
Distributed Port Group |
One context map is supported for this node: ▪Distributed Port Group — displays the ports of this port group and their connected Layer 2 neighbors. |
