If you want to change your password after you have logged in, do the following:
1.Click your username (for example,
) on the quick access toolbar, and select Change Password from the drop-down menu.
Note: If the Change Password menu is not visible, you need to contact your NetBrain administrator for changing your password or authorizing you to change your password.
2.Enter your old password and new password. Click Save.
