Use this API to build or rebuild the Layer 2 topology for all network devices in a domain.
Resource Information
Method
URL
Required authentication
POST
/V1/CMDB/Topology/Tasks/L2
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Response
Parameter
Type
Description
Example
taskId
string
The task Id. It can be used to query task status.
  "taskId""string",
  "statusCode"790200,
  "statusDescription""success"
statusCode
integer
The returned status code of executing the API.
statusDescription
string
The explanation of the status code.
