Use this API to assign users to a domain.
Resource Information
Method
URL
Required authentication
POST
/V1/CMDB/Domain/Users
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Request*required
(body)
The body contains the following parameters:
domainId*(string): the ID of the domain that you assign users to.
users*(list): a list of users you want to assign. It contains two sub parameters:
ousername*(string): the name of a user.
oroles: the roles of a user, such as admin, guest, and engineer.
Example:
  "domainId""3e75247a-309c-4231-96a5-823b6cb1e78d",
  "users": {
    "username""NetBrain",
    "roles""guest"
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
