Alert Console is used to display messages of events occurred during the execution of current Qapp/Gapp, docked at the bottom of a map.
Messages in Alert Console are categorized into four levels: Error, Warning, Information, and System. Levels of displayed messages depend on the selected Run Mode of current Qapp/Gapp.
Example: 5 Error Messages displayed in Alert Console
To filter messages by event level, you can click the
icon to select the target levels.
Note: Only events in Error and Warning levels are duplicated in the Event Console. However, events in Alert Console are directly populated, while events for the same device are merged in Event Console.
