1.Click Path Browser on the taskbar.
2.Click New Path.
1)Enter the source/destination IP address.
Tip: You can also enter device hostnames or DNS names.
2)By default, the system calculates two-way paths. To change the path direction, select the icon or the
icon.
Tip: To quickly swap the source and the destination IP addresses, click the icon.
3)The related gateways will be auto-identified as per your inputs. If a device has multiple gateways, you can select the target one from the Gateway list.
4)Enter the path name.
5)Specify the path analysis set and protocol to be used. See Path Settings for more details.
3.Click OK.
Tip: To calculate the path, right-click the entry in the Path Browser, and then select Calculate Live Network or Calculate Historical Data based on your needs.
