Use this API to create user accounts in the system.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Users |
Yes |
Name |
Token*required |
body*required |
The body contains the following parameters: ▪username* (string): the username to log into your NetBrain domain. ▪email* (string): the email address of the user. ▪firstName* (string): the first name of the user. ▪lastName* (string): the last name of the user. ▪password* (string): the login password. The allowed length is 6-128 characters. ▪authenticationType (integer): the authentication type for the user account. o1: Local o2: External ▪phoneNumber (string): the phone number of the user. ▪department (string): the department that the user belongs to. ▪description (string): the description of the account. ▪allowChangePassword (bool): determine whether to allow the user to change individual password. ▪deactivatedTime (string): specify the time when the account is expired. ▪isSystemAdmin (bool): determine whether to allocate system administrator role to the user. ▪tenants (object): specify a list of tenants for the user. Only required if the value of the isSystemAdmin parameter is false. otenantName (string): the tenant that the user can access. oisTenantAdmin (bool): determine whether to allocate the tenant administrator role to the user. If false, you need to specify a domain for the user to access. oallowCreateDomain (bool): determine whether to allow the user to create domains. odomains (object): required only if the value of the isTenantAdmin parameter is false. odomainName (string): the domain name. odomainRoles(string): the role of the domain user. Specify a tenant for the user. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
