Use this API to add devices to a site.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Sites/Devices |
Yes |
Name |
Token*required |
Request*required |
The body contains two parameters: ▪sitePath* (string): the full path of the site that you want to add devices to. ▪Devices* (list): the devices to be added. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
