Use this API to add a role and grant privileges to the role.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Roles |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪roleName*(string): the name of the role that you want to add. ▪description (string): the description of the role. ▪privileges (string): the privileges that the role owns. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
