Use this API to add a domain.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Domains |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪tenantId*(string): the ID of the tenant that the created domain belongs to. ▪domainName*(string): the name of the created domain. ▪description (string): the description of the domain. ▪maximumNodes*(integer): the maximum licensed node count that the domain owns. The number must be greater than 0. ▪maximumPorts (integer): the maximum number of SDN ports that the tenant owns. ▪maxinumCPU (integer): the maximum number of SDN CPU processors that the tenant owns. Example: { |
Parameter |
Type |
Example |
domainId |
string |
The ID of the domain. |
statusCode |
integer |
statusDescription |
string |
