A free trial license lasts 14 days with 200 device nodes and 25 seats.
1.Log into System Management page.
2.In the System Management page, select the License tab and click Activate. The activation wizard prompts.
Note: If your NetBrain Web Server does not have access to the internet, you can configure a proxy. Click the icon at the upper-right corner, select the Use a proxy server to access the internet check box and enter the required information.
3.Activate your trial license:
1)Select Start Free Trial and click Next.
2)Enter your email address and the activation key that you received from the system.
3)Click Activate.
4)When the activation succeeds, a notification dialog box will prompt. Click OK.
4.A confirmation dialog box prompts to ask you whether to generate an initial tenant. Click Yes and an initial tenant will be created automatically with limited nodes and seats assigned. If you click No, you can create a tenant manually later. See Creating a Tenant for more details.
5.To browse the license information, click the License tab.
▪License Validity — the validity period of your license.
▪Maintenance Expired Date — the expired date of license maintenance (purchased with license).
▪Maximum Node Count — the maximum device nodes that you can discover and manage in the system (purchased with license).
▪Concurrent Seat Count — the maximum user accounts that can log into the system concurrently (purchased with license).
