Viewing Recommended Automation in Guidebook
You can select this Guidebook in the select Guidebook drop-down list.
TIP: Mouse over the Guidebook, and the basic information such as name, ID, description will be shown.
After a manually defined Guidebook is selected, the recommended automations belonging to this Guidebook will be displayed.
The displayed results vary with different types of Decision Tree elements:
Hypothesis
Data View Template
Hypothesis
Meaning
After Clicking
1
a dummy node representing the manually defined hypothesis
N/A
2
the predefined note
N/A
3
the instance of the respective Runbook Template, Network Intent or Network Intent Cluster
Refer to: Viewing Runbook Template or network intent in Viewing Auto Qualified Recommended Automation.
Data View Template
Meaning
After Clicking
1
the manually added Data View Template
Refer to: Viewing Data View Template in Viewing Auto Qualified Recommended Automation.
2
the description defined by user when adding Runbook Template or Network Intent to Data View Template.
N/A
3
the instance of the respective Runbook Template or Network Intent
