View Domain Health Report
Domain Health Report records the key factors about domain health. You can get a quick overview of the current domain status with this report.
2.In the Domain Management page, select Operations > Domain Health Report from the quick access toolbar.
3.In the Domain Health Report tab, click Create Health Report to generate a report.
4.View the highlighted area to get an overview.
5.Check the following areas to get more information.
Driver Associated Device
Basic Network Settings Completeness
Discovery Status
Site Definition Completeness
Benchmark Task Health
Cloud Health
Path Calculation Health
Disk Management Settings Completeness
Map Layout Settings Completeness
The following table displays the count of devices discovered by corresponding drivers. Device driver defines the method of retrieving and parsing device data during live access.
Note: See Device Driver for more details.
The table lists the information in Network Settings, API Server Manager, and CheckPoint OPSEC Manager.
Index
Description
Condition Calls for Attention
Front Server (defined)
The count of stand-alone Front Server served in a domain
count = 0
Front Server (unused)
The count of stand-alone Front Server that is allocated with 0 device
count > 0
Front Server (with over 5000 devices)
The count of stand-alone Front Server that is allocated with more than 5000 devices
count > 0
Front Server Group (defined)
The count of Front Server Group served in a domain
N/A
Front Server Group (unused)
The count of Front Server Group that is allocated with 0 device
count > 0
Front Server Group (with over 5000 devices per Front Server)
The count of Front Server Group that is allocated with more than 5000 devices
count > 0
***1) (defined)
The count of defined ***
count = 0
***1) (unused)
The count of *** with 0 device
count > 0
API Server
The count of defined API Server
N/A
CheckPoint OPSEC
The count of defined CheckPoint OPSEC
count = 0 when there is CheckPoint R77 in a domain
No mark required when where is no CheckPoint R77 in a domain
Note: 1) *** represents Private Key, Jumpbox, Telnet/SSH Login, Privilege Login, and SNMP String.
Discovery Status
The table lists the discovered device summary and licensed node usage.
Index
Description
Licensed Node Usage
The usage of license
N/A
Fully CLI-Accessed Rate
The rate represents the percentage of Fully CLI-Accessed Devices among All Discovered Devices, except Don't Support CLI devices and other devices.
N/A
The devices that the system discovered via CLI.
N/A
SNMP-Only Devices
The count of devices in Fine Tune > All Discovered Devices > SNMP-Only Devices
count > 0
Unknown SNMP SysObjectID
The count of SysObjectID in Fine Tune > Unknown SNMP SysObjectID
count > 0
Unknown IP
The count of IP addresses in Fine Tune > Unknown IP
count > 0
Missed Devices
The count of devices in Fine Tune > Missed Devices
count > 0
Subnet with Conflicted IPs
The count of subnets in Fine Tune > Duplicated IP and Subnet Manager when All Zones is selected
count > 0
Zone
The count of Zones in Fine Tune > Duplicated IP and Subnet Manager
count = 0
Note: Because of the existence of Default Zone, the count of Zone cannot be equal to 0.
Hostname Change
The count of devices with hostname changed in Fine Tune > Hostname Change.
count > 0
The table lists the summary of site information.
Index
Description
Container Site
The count of Container Site
N/A
Leaf Site
The count of Leaf Site
N/A
Leaf Site (with 0 device)
The count of Leaf Site with 0 device
count > 0
Leaf Site (over 100 devices)
The count of Leaf Site with more than 100 devices
count > 0
Unassigned Device
The count of unassigned devices
count > 0
The benchmarks whose results display as Succeeded with Warning or Failed will be marked with in Attention column.
Cloud Health
This area shows the basic information of the existing clouds in the current domain. Blank NCT includes those tables with headers only. When the count of blank NCT exceeds 0, the attention icon will display.
This area shows the summary of path calculation, such as the count of total paths, the count of paths that are successfully calculated, and the count of paths that are not calculated. The status pane is categorized by Succeeded and the causes of failure.
Global Data Clean Settings
The table lists whether the data in Global Data Clean Settings is enabled or not.
Index
Data Engine Data
Disabled
Qapp/Gapp Execution Logs
Disabled
One-IP Table Entries
Disabled
Discovery/Benchmark Logs
Disabled
Application Path History Data
Disabled
DataUnitStorage
Disabled
Backup Maps
Disabled
API Triggered Automation Task
Disabled
Event Entries in Every Console
Disabled
Execution Logs for Scheduled Data View Template and Parser Tasks
Disabled
Dashboard Activity Data Table
Disabled
Compare Results
Enabled
MongoDB Disk Alert Rules: (System Settings)
The table lists the settings of MongoDB Disk Alert Rules in Service Monitor.
Index
Description
Send emails when alert detected
Whether to be enabled
Disabled
Send emails and delete Data Engine data when alert detected
Disabled
Send emails and disable write permission to MongoDB when alert detected
Disabled
Email Address
Whether to be configured
When the Email Address is not configured and at least one of the above rules is configured.
Note: If Email Address is configured, status is Configured, if not, status is None.
The table lists the information in Map Layout Manager.
Index
Description
Customized Layout
The count of customized layouts in Layout Styles and Sample Maps, except for built-in layouts
count = 0
Devices with Tags Associated
The count of devices with tags assigned
N/A
Devices without Tags Associated
The count of devices without tags assigned
count > 0
Site Maps with Layouts Associated
The count of sits maps with layouts associated
N/A
Site Maps without Layouts Associated
The count of sits maps without layouts associated
count > 0
