View Device Health Report
When working on a map, you may run into various anomalies of devices, such as a live access issue, a topology issue, or a path calculation failure across a device. Device Health Report provides device-level health status to help with map success.
You can analyze the report from the aspects such as Basic Information, Topology, and Path. See Device Health Report Details for more information.
1.On a map page, right-click the target device and select Diagnosis > View Device Health Report.
Note: You can also click the start menu  and select Device Health Report to generate a report about all devices in the current domain.
2.Click Check This Device Health to generate a report for the current device.
Note: The attention () is a reminder to ask for your attention. If remedy action is not necessary, you can ignore it.
The table lists the summary information of the report.
Category
Index
Condition Calls for Attention
Basic Info
Driver
N/A
Site
The device has not been assigned to a site.
Live
Ping
CLI Connection
CLI Non-Privilege Login
CLI Privilege Login
The value is Failed.
Discovered by SNMP Only
Missed Device
Hostname Changed
The value is Y.
SNMP RO
SysObjectID
SNMP Hostname
First Discovery Time
Last Discovery Time
N/A
Data Saved in Current Baseline
Configuration File
Route Table
ARP/MAC/NDP/STP Table
BGP Advertised-route Table
ARP Switch Table and so on
N/A
Topology
IPv4 L3 Topology - Isolated Device
IPv6 L3 Topology - Isolated Device
L3 VPN Tunnel - Isolated Device
L2 Overlay Topology - Isolated Device
The value is Y.
L2 Topology - NDP Collected
The value is N.
L2 Topology - Isolated Device
L2 Topology - Transparent Device
The value is Y.
IPv4 L3 Topology - Summary
IPv4 L3 Topology - Duplicated IP
IPv6 L3 Topology - Summary
IPv6 L3 Topology - Duplicated IP
L2 Topology - Summary
L3 VPN Tunnel - Summary
N/A
Path
Path/Application name
The path across the device fails.
