System Task Manager provides information about all back-end processes, including discovery/benchmark tasks, scheduled Qapps and so on. It automatically breaks a task into threads and enables you to end each process manually. Refer to System Task Status for more reference.
To terminate a task, complete the following steps:
2.In the System Management page, select Operations > Task Manager from the quick access toolbar.
3.Select the target task and click End Process.
System Task Status
The following table explains various status of a system task.
Status
Description
Running
The task is being processed.
Ready
The task is ready to be processed.
Pending
The task is waiting in the task queue.
Completed
The task is completed.
Error
The task encounters an error during processing.
Terminating Processes
