Alerts for Golden Baseline anomalies can be timely shared with more relevant users via system alerts, or email alerts, or both.
By default, only authors/modifiers (for scheduled Data View Template) or executors who apply/run a Data View Template can receive Golden Baseline alerts. Meanwhile, the system provides Alert Settings for sharing these Golden Baseline alerts.
You can configure the following alert settings when you apply a data view template to a map, run a data view template through a runbook, or schedule a data view template task.
Alert Settings for Data View Template Monitoring Alert Settings for Scheduled Data View Template Task
Field |
Share Alert with |
Enter a username and then select the matched user account from the drop-down list. |
Send Email to |
Enter at least an email address. Note: Multiple email addresses must be separated with a semicolon. |
Duplicate an alert in emails when alert count increases by |
The delta threshold (defaults to 7) controls when the system will email an alert again if it is repetitively recurring and increasingly reaches the value. |
