To keep your network data up-to-date, you can schedule to perform benchmark and discovery tasks regularly.
The system provides the following built-in tasks:
▪Basic System Benchmark — regularly collects live data as baselines to build topology, calculate paths, and recalculate device groups, sites, and MPLS Virtual Route Tables.
▪Scheduled System Discovery — discovers new devices in your network and adds them to your domain automatically.
In addition to the built-in tasks, you can define your own tasks. See Creating Benchmark Tasks or Creating Discovery Tasks for more details.
Note: Make sure that Front Servers can successfully access your live network via SNMP/Telnet/SSH before task execution. If one task is still running when the next execution cycle starts, the next cycle will be canceled to avoid duplicates.
As soon as a task is executed, the corresponding Execution Log is generated. You can check the task result or troubleshoot a data retrieval failure in logs. The retrieved network data is stored in the Current Baseline.
